Octane #
blackcat54
Octane #
What type of gas are you running your Forza on?
I see the manual calls for 91 octane (premium).
Can regular 89 octane be used?
Re: Octane #
blackcat54 wrote:What type of gas are you running your Forza on?
Yes
blackcat54
Re: Octane #
I don't know why, but the online manual says to use 91 octane.
Happy to hear that it runs on the cheaper grade!
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
Re: Octane #
Given how little gas these scooters take, it seems a minor quibble. The difference in a fill up will be... what... fifty cents?
Re: Octane #
Use what the manual recommends for your country.
Octane ratings are not the same across the world.
As for the old question of is a higherrating better, then no, for a scooter there is absolutely no benefit whatsoever using a higher rating than the one listed in the manual.
Re: Octane #
Depends on what you mean by doesn't hurt.
If you want less power, worse fuel consumption and a risk of burning your exhaust valve, go right ahead.
Re: Octane #
Can i nominate this for the Preposterous Statement of The Year Award?gn2 wrote:a risk of burning your exhaust valve, go right ahead.
It's not like the op is considering racing gas. lol
Re: Octane #
Which statement in particularscisor34 wrote:Can i nominate this for the Preposterous Statement of The Year Award?gn2 wrote:a risk of burning your exhaust valve, go right ahead.
Re: Octane #
Premium is not Avgas.gn2 wrote:Depends on what you mean by doesn't hurt.
Current - 2015 Honda CBR650F
stryder123
- Year: 2014 forza
Re: Octane #
An understanding of how octane works will put an end to a lot of questions like these.
http://auto.howstuffworks.com/fuel-effi ... tion90.htm
Re: Octane #
I just like fuel without ethanol. To get that, I have to buy premium.
Re: Octane #
DennisG wrote:I just like fuel without ethanol. To get that, I have to buy premium.
Cheapest for me
blackcat54
Re: Octane #
What's wrong with ethanol?
Re: Octane #
Ethanol is great for the environment and jobs for North America were less dependent on the oil country's , also ethanol is usually higher octane but it's corrosive , (most newer cars and motorcycles can use up to 10% ethanol in the gas,)less power per volume,so less fuel economy and some says it doesn't store as long
Re: Octane #
Forza 300 wrote:Ethanol is great for the environment and jobs for North America were less dependent on the oil country's , also ethanol is usually higher octane but it's corrosive , (most newer cars and motorcycles can use up to 10% ethanol in the gas,)less power per volume,so less fuel economy and some says it doesn't store as long
Countries?
Re: Octane #
North America only. It's always about us......you you wrote:Forza 300 wrote:Ethanol is (supposedly) great for the environment and jobs (not confirmed) for North America where less dependence on foreign oil is important. Also ethanol has a higher octane rating but has less BTU output per equivalent unit gasoline and is corrosive. Most newer cars and motorcycles can utilize up to 10% ethanol.
Countries?
- willajabir
Re: Octane #
Let me see if I understand this,
Add 10% ethanol reduces my mpg approx 10%, so I have to burn 10% more to go the same as before?
I am now burning ethanol which I didn't before and this helps saves the environment?
By diverting a food product to gasoline, I guess this will help the hungry?
It deteriorates auto components faster thus raising the cost of ownership while increasing the parts requirements that otherwise would have been less?
So farmers are subsidized and by increasing consumption, tax coffers are increased.
Did I miss something?
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
Re: Octane #
Nope that's pretty much it. Oh wait,...this Ethanol thing is mostly politically motivated.willajabir wrote:Let me see if I understand this,
You did forget to mention that.
