swap out panels
swap out panels
Hello, I tried to search this topic first, but didn't see any result. I have a pcx 150, but wanted to swap out the panels from a white 125 to the 150. Was curious if everything would fit. This is on a US PCX btw.
Re: swap out panels
This discussion has some info http://hondapcx.org/posting.php?mode=quote&f=19&p=33277
Re: swap out panels
I didn't see any confirmation in that link. I know that there are slight teaks with the center gas cap plastics, so im wondering if that will affect the plastic swap at all.
Re: swap out panels
I have a 2013 PCX 150. We had to replace several panels on it. I ordered replacement panels from Bikebandit.com. At that point in time they only had parts for the PCX 125. I have no idea if they now have parts for the 150, but the point is that the replacement panels fit perfectly. So I would have to say from experience that the panels are interchangeable. I think it is only the none painted, or rather the flat black ones, that probably won't fit.
