Grocery Shopping!
cfrobw
Grocery Shopping!
Post by cfrobw »
Hm, here is an idea I just came up with to help with groceries. Don't know if it can be done or not, but Thule has a child carrier that's designed to be hooked to a bicycle. Could there be a way to connect it to a PCX to carry groceries?
http://www.thule.com/en/gb/products/act ... _-10100818
-Rob
Currently own: 2013 PCX 150
Previously owned: 1987 Honda Elite 80, 1993 Honda Elite 80, 2008 Honda Elite 80, 2010 Honda Elite 110
buddy1976
Re: Grocery Shopping!
Post by buddy1976 »
cfrobw wrote:Hm, here is an idea I just came up with to help with groceries. Don't know if it can be done or not, but Thule has a child carrier that's designed to be hooked to a bicycle. Could there be a way to connect it to a PCX to carry groceries?
Or better still stick the baby in it when its screaming its head off and go for a spin!
Honda forza 125 2019
Yellow malossi contra spring
Malossi delta clutch and bell
Malossi special kevlar belt
K and n air filter
Akrapovic exhaust
Malossi White Contra Spring
Malossi yellow clutch springs
Daytona reinforced belt
DNA Performance air filter
Removed air box flange
Removed seat hump
Ermax+25 windshield
yttikeiram
Post by yttikeiram »
In my opinion, this is a very bad idea. The tire on that carrier would wear off, even if you COULD get it on your scooter and go at very low speeds. If you really need to carry a lot of groceries, you could get the following:
Tank Bag
Saddle Bags
Seat Bag
Luggage Rack
Top Case
There are some cheaper saddle bags that work well, and they can even have a matching seat bag. If you don't like the idea of a top case, you could get a very durable duffle bag and tie it to your seat and/or luggage rack. I do know people who have the top cases also tie down a back pack in front of it, and you can even tie down other stuff to that back pack.
All of these bags will carry quite a bit of groceries. If you have a bicycle, you can get a Burley Travoy, bungie a plastic hamper to it, and there you go. If you live close to a store, the Travoy can also be used off of a bicycle to lug around groceries. It has a 60 lb weight limit, and folds for storage. I think you'll get quite a bit with your scoot, though.
willajabir
Post by willajabir »
Lengthy discussion about this before:
http://www.hondapcx.org/viewtopic.php?f=2&t=1452
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
Ya, what yttikeiram and Larry said ... not a good idea, and may likely even not be legal, depending where you live.
If I were you I would consider a Givi tailbox and some soft side cases. I have seen pictures of some that someone has on this forum. You drape them across the PCX and close the seat to keep them in place. They looked pretty big, and the tailbox holds a lot too, so I think you would have enough storage to carry all of your groceries.
I'd be concerned about bearings... That cart isn't designed to go that kind of speed, and would probably wobble erratically.
There's a whole crapload of posts about dualsport trailers here: http://advrider.com/forums/showthread.php?t=113997 -- it's a good read.
hatari
Post by hatari »
.....over here, 35L Givi box, hook on handlebars...and under seat storage...
just how much more would you want ??
willajabir
hatari,
her in the USA, it is very common to purchase 1-2 weeks of supplies per trip to the grocer. If he has a passenger to assist in the shopping, it would easily be over the skuder storage capacity.
Larry
Kermit
Scootering Amphibian
Post by Kermit »
I have one of those carriers for use with my bicycle. I would never, ever, ever consider hooking it up to a scooter...not a chance. It's simply not stable enough.
