NERTIA POWER BOOSTER SET YUMINASHI
dem0nk1d
Post by dem0nk1d »
Anyone care to break this down for me and what it actually does. I read it twice and don't understand what it's doing.
http://www.yuminashi.com/-pcx150-inertia-power-booster/
http://www.pcxracing.com/product.php?id_product=11
Alibally
Re: NERTIA POWER BOOSTER SET YUMINASHI
Post by Alibally »
It basically just a flywheel. It keeps the engine momentum going as a single cylinder engine has only one power stroke per 4 revolutions.
dem0nk1d
Post by dem0nk1d »
if it's a flywheel, this is adding weight and also that the bike is a CVT type system when the bike drops in RPM the belt changes slowing the bike down. Also you have a flywheel already in the bike for the stator / generator system. The mag or some people call it a flywheel.
Part #1 Flywheel
Alibally
Post by Alibally »
It's fitted on the other side of the crank at the cooling fan/radiator side. It works the same as a car flywheel dampening out vibration. The disadvantage of a heavy flywheel is that it revs up slower as the engine has to build up the momentum of the flywheel, but once the revs are up they don't slow down as quick. Race cars have lightened flywheels/ clutches for the opposite effect.
wingz
Color: Dark Silver
Post by wingz »
May be remotely helpful in gusty headwinds but I wouldn't bother with it.
dem0nk1d
Post by dem0nk1d »
to me i'd rather reduce weight getting the rpms to speed and being able to hold the throttle in position to keep me going. i understand the idea of making things heavier to keep the objects momentum going, but this just sounds crazy.
Alibally wrote:It basically just a flywheel. It keeps the engine momentum going as a single cylinder engine has only one power stroke per 4 revolutions.
2 revolutions?
Alibally
Post by Alibally »
2 revolutions?
Yes you've passed.
Have a gold star
Mgalutia88
Year: 2013 PCX 150
Post by Mgalutia88 »
2 revs = 2 stroke you you
Mgalutia88 wrote:2 revs = 2 stroke you you
1 rev = 2 stroke
Alibally wrote:
2 revolutions?
Yes you've passed.
Have a gold star
It was a test :D
Mgalutia88
Year: 2013 PCX 150
You're right you you. Thank you. I had to think about it lol.
stryder123
Year: 2014 forza
Post by stryder123 »
On a 4 stroke engine, when the piston comes up top it is either an exhaust stoke or power stroke.
So power stroke every other time.
Mgalutia88 wrote:You're right you you. Thank you. I had to think about it lol.
:) no probs,you made me think twice
stryder123 wrote:On a 4 stroke engine, when the piston comes up top it is either an exhaust stoke or power stroke.
Two "strokes" to every revolution
Mgalutia88
Year: 2013 PCX 150
I know I know. Just hadn't thought about it in a while lol.
mikelx5
Post by mikelx5 »
so i have tested the inertia booster on my 150 with pipe and intake and yumi vario it will still make it to the 70mph and downhill i even got to 80 but takes longer to get there. that being said if you stay off the highway it gives u a lil more kick on the flats and you can carry your speed a lil longer on the hills. if i had more power i would leave it so im gonna hang onto it but for now my yumi with 11g rollers it has more on the top end. big bore with cam and manifold would prolly benefit i just dont have the power.
DISOBEDIENCE CREW
mikelx5 wrote:so i have tested the inertia booster on my 150 with pipe and intake and yumi vario it will still make it to the 70mph and downhill i even got to 80 but takes longer to get there. that being said if you stay off the highway it gives u a lil more kick on the flats and you can carry your speed a lil longer on the hills. if i had more power i would leave it so im gonna hang onto it but for now my yumi with 11g rollers it has more on the top end. big bore with cam and manifold would prolly benefit i just dont have the power.
It's not a power booster its just a washer.
mikelx5
Post by mikelx5 »
not really its a wieght thats almost the size of the flywheel
DISOBEDIENCE CREW
hatari
Post by hatari »
listen to yer uncle Percy - "Leave well alone".................
