Are the North America Pcx 125 & 150 plastics the same? Needs some replacement panels for me 150 and can get a hold of some 125 plastics for cheap.
TIA!
AIM: JDMCHRISDOTCOM
www.IERUCKS.com
www.IERUCKS.com
Re: 125 & 150 plastics the same?
I don't know if ALL of the pieces are interchangeable but I do know that some are because I have replaced several of the panels on my 2013 PCX 150 with those advertised on Bikebandit.com.com as for 2011 PCX 125. They fit without any modifications what so ever. Even the color was correct, and I have a red PCX, which had been a question when I ordered the parts. Soooo, I would say that most of them are a safe bet. Order them and try them. That is the best answer I can give you. They worked for me but there could be some that don't fit. I just wouldn't have a clue as to which ones wouldn't. As a clue, one of the panels I ordered was for the right front cover. Good luck.;-)
The painted tupperware itself is identical. I am fairly sure the glovebox and fuel flap area were improved with the 150, and will not quite fit right.
the plastics are not the same......including the petrol flap....
I said the painted plastics... The center plastics that are black plastic, not painted, are different.
