Hi,
Anyone found an electronic copy of the parts manual?
I found this site that has on line diagrams etc. and sells parts http://www.hondapartshouse.com/oemparts ... a-ac-parts but no luck with a download copy anywhere.
Thanks,
Chris.
Parts Manual
Re: Parts Manual
We had posted a parts diagram on this forum previously. However, I don't think it put any names to the parts, just numbers. I will look in my service manual. Maybe there is a section on that.
- willajabir
Re: Parts Manual
To save a website:
A work around is to use Chrome browser. You have to save each section separately, but it works.
For example, goto the wiring harness page, on the menu click print, choose PDF, then save.
Using Firefox, you can use UnMHT plugin, open each parts page as a tab, then save it all as an MHT file.
Another for Firefox is Scrapbook Plus. Reviews say this works more like what you want, but it is incompatible with my browser so I can't test it.
HTTRACK is another addon you can google for. I've used it several years ago and it worked great.
Check them out and let me know which one you chose to use and worked best for you.
Larry
2014 NSS300E born on 12/11/13
May the Forza be with you
my Forza pics: http://tinyurl.com/o9hqc4o
- willajabir
Re: Parts Manual
Thanks Mike,
Kinda obvious wasn't it...everything else for the Forza is in Thailand
Larry
