Best way to place trickle charger leads?
gokidd
Post by gokidd »
Weather's catching up with us ... not riding very much. (Especially not with this head cold that won't leave.)
How/where are folks installing the trickle charger quick-disconnect lead for the PCX battery?
What is the best way to place it so that it's quick to connect/disconnect without having to pull and replace bodywork?
I appreciate the help!
Let us boogie ...
Honda PCX 150
Yamaha Majesty 400
gokidd
Re: Best way to place trickle charger leads?
Post by gokidd »
I guess another way to ask the question is -- does everyone just remove the battery door and leave the seat open when using a trickle charger?
Or is there a better way?
Thanks.
Let us boogie ...
Honda PCX 150
Yamaha Majesty 400
chucktuna
I'm up to 12 or 13 now...
Post by chucktuna »
I haven't done mine yet, but it appears that there is enough gaps around
the edge of the access door to have allow room for the lead to be left in place with just the end sticking out into the under seat compartment. That's my plan.
My little Elite 110 has the battery under the nose, so I just let it poke out from one nostril:
Darth Emma
Post by Darth Emma »
The battery tender pigtail on my Forza fits through a small gap under the seat that leads down to the battery. I'd expect you'd be able to do something similar on a PCX150.
On my Ruckus, I installed a 12V outlet on the battery box and I use that (I bought the battery tender adapter for the cig lighter).
Rides 2014 Honda Forza, 2012 Honda Ruckus
gokidd
Post by gokidd »
I like the nostril application, chucktuna ... very eerie in a sci-fi fashion.
I will check out the gap space on the battery door.
Thanks!
Let us boogie ...
Honda PCX 150
Yamaha Majesty 400
Tom192
Post by Tom192 »
Ctek quick release coupling attaches to the battery and squashes in so you can put the battery cover back on so all you do is open battery door and connect :)
GeorgeSK
Year: 13PCX,15Forza
Color: Both Red
Post by GeorgeSK »
Crude but effective...
Mantis charge wire.jpg (389.02 KiB) Viewed 18237 times
Optimate ring adapter that came with charger.
The door is flexible enough so that there is no strain on anything. I think it will work for me.
OriginalRocket
Post by OriginalRocket »
Or... Just pull the battery and clip on the clamps from the battery maintainer. Trickle charge is not a good way to. You want one that "floats" a charge.
I have one battery maintainer I move round to 4 batteries. They sit in a line. Each week I move the clamps down the line. Works well.
oakies
Post by oakies »
I just removed the battery cover and connected it to the battery, I leave the battery cover off for the winter and just leave the lead lying in the underseat compartment for the winter. In the spring, Ill just remove the lead for the summer. No riding here in Buffalo NY for 4 months anyway. Or you could just put a little notch in the battery cover for the wire and leave the lead hooked up permenantly.
Current - 2013 Pcx150 - 2013 Harley Superglide - 2002 Suzuki GZ250
I've seen it run through the fuel flap. That would work and not pinch the cable under the seat. It's easy enough to squeeze the cable through if you remove the battery and the fuel flap cover panel.
gokidd
Post by gokidd »
Yep, ya'll convinced me -- leads out through the battery door.
I intend to ride most any pretty weekend this winter, so I don't want to remove the battery altogether.
And I did say "trickle charger", but I agree that a battery maintainer (like Battery Tender) is what I'll be installing -- easier on the battery.
Good point!
Let us boogie ...
Honda PCX 150
Yamaha Majesty 400
Gn2s testicles?
scisor34
Post by scisor34 »
That's assuming he has a pair.........
gokidd
Post by gokidd »
you you wrote:Re: Best way to place trickle charger leads?
Gn2s testicles?
Now there's a battery remark with specific gravity.
Let us boogie ...
Honda PCX 150
Yamaha Majesty 400
