Step, body, and seat mods
kstrayhorn
Post by kstrayhorn »
I recently got a 2013 PCX150 and have wanted to make a few changes. I was browsing partzilla.com and found a few things. First, I had a little mishap and the kickstand wasn't down when I thought it was, so I scuffed the paint on the lower side panel. I'm wanting to get some replacements and have them rhino lined for a more durable finish. When I do that, I'm wanting to do the same for the inside step pieces. I found these parts:
http://www.partzilla.com/parts/detail/h ... N-900.html
http://www.partzilla.com/parts/detail/h ... 900ZB.html
It says these parts are for a 2011 125, but is it not true that they will work for my 2012 150?
Also, since the painted parts come painted, has anybody worked with them and know if there are any problems with prepping them for refinishing?
Second, I am too tall for the seat, so I have to ride on the rear section of the factory seat with my feet on the rear steps. I'm wanting to modify the seat to remove the hump, but I also need to keep an OEM seat. When browsing for parts, I found a couple of options, but neither has a picture:
http://www.partzilla.com/parts/detail/h ... 902ZC.html
http://www.partzilla.com/parts/detail/h ... 901ZC.html
What is the difference between these two parts (one says NH1L) and will one, either, or neither work for my application since the one listed is a 2011 125?
Thanks in advance for your help.
Mgalutia88
Year: 2013 PCX 150
Re: Step, body, and seat mods
Post by Mgalutia88 »
Check your local dealers website. If they don't have the link to the oem parts catalogue go to www.advantagepowersports.com this dealer has the link. From that link you can find your parts. Don't bother with the 2011 side panels. These should be the same part, just not in your color. (I have a 2013 150 also. You can get either red or black side panels for $15 and $17. If memory serves correctly the side with the kickstand hole is the more costly one. The panels come polished and ready to install.
sendler2112
Year: 2013 PCX150
Post by sendler2112 »
a seat humpectomy will let you slide back for more legroom. You could also take the cover off to add some foam to make it taller.
kstrayhorn
Mgalutia: thanks for that, I don't know how checking local dealers slipped my mind. That solves that problem because the site I linked only had red and white when I need black.
Sendler: I was wanting to take the hump out of my seat, but any part that I modify irreversibly (cutting out the plastic mount and reupholstering) I have to have a second part that is stock. That's why I linked the two different seats because I didn't know if one had the hump and the other didn't or what because neither has a picture. If I can get one without a hump, I can just buy that one and keep my current one stock rather than buying a second seat and then paying more to have it reupholstered.
Thank you both for your help.
