Broken threads
Scottish
Broken threads
Post by Scottish »
I'm using a ratchet wrench, trying to un-tighten a bolt...the thread seems to be broken resulting in the nut turning but never slackening.
Any tips on how to un-tighten a nut from a bolt with busted threads?
Alibally
Re: Broken threads
Post by Alibally »
What are you trying to remove?
Taz
Re: Broken threads
Post by Taz »
Are you sure you are not turning the whole bolt as well? Can you get access to the bolts head?
Scottish
Re: Broken threads
Post by Scottish »
I'm trying to remove the seat hump, cant really tell if the bolt is turning or not... :(
Re: Broken threads
Scottish wrote:I'm using a ratchet wrench, trying to un-tighten a bolt...the thread seems to be broken resulting in the nut turning but never slackening.
Try using a plain ring spanner while pushing down hard on the exposed threaded section with your thumb
If it is stripped try using mole grips on the threaded section?
Re: Broken threads
Scottish wrote:I'm trying to remove the seat hump, cant really tell if the bolt is turning or not... :(
I can almost guarantee you that it is the bolt spinning. If you can't hold the bolt while spinning the nut, try cutting a groove into the end of the bolt and holding it with a flat screw driver while spinning the nut with a spanner (UK) / wrench (US).
Scottish
Re: Broken threads
Post by Scottish »
thanks for the advice.. i'll give it a go.
dasshreddar
Year: forzaruckuspcx
Re: Broken threads
Post by dasshreddar »
Did you get that hump off?
If your not going to save the hump, you could always just cut into the hump to get to the back of the bolt. ;)
Scottish
Re: Broken threads
Post by Scottish »
no luck yet dasshreddar, i'll probably just leave it where it is for now.
