Hand gaurds
Hand gaurds
Hi any one fitted hand gaurds any good?any recommendations for which ones thanks
mymitzi
Re: Hand gaurds
If you are interested in protection from the cold.........handlebar muffs are superior, although, not as pleasing to look at.
https://www.ebay.com/sch/i.html?_from=R ... s&_sacat=0
Re: Hand gaurds
All ready have muffs find them awakard to use very bulky
mymitzi
Re: Hand gaurds
Understand.........I tried the hand guards first............helped some but not enough. The muffs I have are easy/ quick to install/remove.
Not fond of the look......... but when it's really cold.........they get the job done.
Re: Hand gaurds
I don't have them on any more but I made some hand guards out of clear plexiglass. It was easy enough, and I used a heat gun to bend the plexiglass as needed. Putting holes in the plexiglass was easy enough as long as I took my time. You could also heat the drill bit, but I think just putting painters tape over the spot you want to drill out should work. Reinforce that area afterwards with aluminum so the vibration won't crack it when riding.
fullmetalscooter
Re: Hand gaurds
I ve done it but if you DYI it understand drill out plexiglass with normal drill bits will crack it . You should buy a drill bit made for it . Really I just bought some cheap ass 10 bucks hand guards . The mount didn't fit so being lazy I duck tape them in place . Year after year . Also bent old motorcycle lic plates over them to add more hand covering . if you re into 3d printing you can make your own
