Countershaft Change - Best speed for least effort.
Ozzibiker
Color: Pearl Blue
Post by Ozzibiker »
These details are for a 2014-2018 model PCX150.
Maddiedog put up a great post about changing the final drive gears.
https://www.hondapcx.org/viewtopic.php?p=61957#p61957
However, you don't need to press out the gears to make a big change.
By only replacing the countershaft sprocket (number 6 in about image), you can make big changes.
Here is a table of the speed changes for different gears.
Excel File of gear ratio calculations
Gear Ratios.png (48.38 KiB) Viewed 29551 times
You can see my driveshaft, counter gear, and final drive are the stock teeth number, but I only changed the countershaft to a 16T (tooth), and it gave me a 23% better speed (compared to Maddiedog's 25%).
This is the site I used https://www.yuminashi.eu/
and this is the product https://yuminashi.eu/countershaft-16-te ... 50-adv150/
I've had it running for 8,000km and just checked the sprocket. It still looks good.
You'll need to check any products against your scooter model number.
Importantly, I didn't do this to make the scooter a lot faster, but do reduce the engine rpm.
AT 120km/h on a flat road the scooter wouldn't go faster. You'll need to change the cylinder head for that.
This is a table of the changes in engine rpm.
Engine rpm change
Engine rpm change
RPM Change.png (6.87 KiB) Viewed 29551 times
Good luck.
Honda PCX 150 - 2016
Honda VFR400 - 1989
