Hi Board.I need to locate bigger wider tires for my front and rear for my PCX 2016. I dont think my oem rim will fit the bigger tire size so I will buy a bigger rim as well
My tires demision read as below
Front Tyres - Rims dimensions 90/90-14
Rear Tyres - Rims dimensions 100/90-14
Thank you
Need Help Honda PCX 2016 Tire Size - Need Wider Size Tire
- airhead83
- Year: 2025 US
- Color: Pearl Gray
Re: Need Help Honda PCX 2016 Tire Size - Need Wider Size Tire
There's been a discussion on this idea before if you care to read it. It may or not help your decision.
https://www.hondapcx.org/viewtopic.php?t=10904
120/70R14 Front
140/70R14 Rear
Biggest you can go with no modifications.
140/70R14 Rear
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Z-Bars
NCY Variator
I dont need to replace the rim right. Just buy the tire and get it replace by the dealer. Thank you
Question about 140/70R14 Rear
What is 1 lower 1 level of this tire?
130/80R14? I am total a noob in this area
Is there any problem to put same tire 120/70R14 Front on both rear and front?
Thank you
Thank you
You can run same size front and rear but I would recommend running a larger rear. Gives a more stable ride at speed.
2017 PCX 150
Z-Bars
NCY Variator
Z-Bars
NCY Variator
