Suspension lift kit
Mon-Eye
Year: 2021
Suspension lift kit
Post by Mon-Eye »
So I ride on some rough roads and terrain quite regularly (4 miles a day) and decided some extra ground clearance would help. Also got new shocks and fork rebuild kit on order too which should help too. So bought some 50mm rear shock extenders and I'm quite happy with the extra clearance. Bike seams to handle nicely with them on too but havent pushed it hard in the dry yeh.
Re: Suspension lift kit
Nice mod. I bet that helps with cornering too - I always dragged the centerstand and lift would get it higher off the ground!
Mon-Eye
Year: 2021
Post by Mon-Eye »
maddiedog wrote: Mon Apr 01, 2024 6:27 pm Nice mod. I bet that helps with cornering too - I always dragged the centerstand and lift would get it higher off the ground!
Yeh makes it turn in alot nice and makes it more agile too. Has added quite a bit extra clearance and both stands still work fine too
Lrhpkk
Year: 2023
Post by Lrhpkk »
Hi,
Off topic because I cannot PM the moderator.
Can someone please tell the moderator he has another spammer to delete: Bogdannmf appears to be an unwanted intruder.
Thankyou
airhead83
Year: 2025 US
Color: Pearl Gray
Post by airhead83 »
Lrhpkk wrote: Sat Apr 06, 2024 2:08 am Hi,
Thankyou
In the upper right side of every page near your avatar, you'll see a set of 'quotation marks' (") and 'explanation mark'(!).
If you click on the (!) it will send you a "Report" page. Follow instructions from there.
Lrhpkk
Year: 2023
Post by Lrhpkk »
Ah yes. Thankyou.
