Took my 2014 Forza to the shop Saturday for a set of tires. On the way home, after about 30 miles the ABS light started flashing. I pulled over, shut it down and re-started. Light stayed out, but now there is a strange chirping noise, occasionally from the front and back.
Any ideas?
ABS issue after tire change
- Year: 26 adv 160
Re: ABS issue after tire change
Yeah, don’t put up with this crap, they did shotty work, take it back. Obviously, they didn’t take it out for a test ride before they gave it back to you. Raise hell.
YOU should not be the one that’s responsible to do a test ride.
Got correct size tires now. Problem solved.
