fuel problem
fuel problem
Hi all i was riding my 2017 pcx125 to work on the morning 20th feb 2023 when it just cut out i have a brand new spark plug from honda which i put in i have a spark i have compression the fuel pump is working as i disconnected from injector and it pumped fuel when ignition is turned on it looks like a problem on the injector side i swapped the injector with a known good one but it still won't fire up seems like a electrical problem but i am now at a loss as i don't know what the problem could be would be very greatful for any help on this issue
Monty
- Year: 2012
Re: fuel problem
Hey phillip - did you track down the issue in the end?
