Going to finally install heated grips, but first got my scooter upgraded to a newer 160 ABS version (Indonesia).
It has a built in USB socket with 5V 2A marking. As I understand, it has a separate wire and 5A (12V) fuse for it. Would it be reasonable to connect the heated grips (which are approx 2A 12v) to that wire? (not the USB itself is course) - to avoid the hustle of reaching the battery, relays, etc.
PCX 160 power socket amps?
