Hi guys, after having my forza 125 for a year now I’ve decided to go for the bigger engined 350.
My question is can I expect more in acceleration and top end speed?
My daily commute consists of b roads and motorway driving, I just feel the 125 struggles at motorway speeds..
Honda Forza 125 v 350
- E4ACACD9-F199-4F8D-8651-C80AAE48AD44.jpeg (518.96 KiB) Viewed 14102 times
- ghmpm
- Color: red
Re: Honda Forza 125 v 350
I am not familiar with the 125 but my experience with my 2015 300 is it is great on back roads, speed wise. It will do freeways but will lag down on serious uphill rides. Based on this I would assume that the 350 would be even better. So my educated guess is you would be better off with the 350! Good luck.
Glenn
2015 Honda Forza 300
2012 Honda Silver Wing
2005 Honda Goldwing Trike
- DAB
My 350 easily does motorway speeds.
Other rides
thanks for the reply,
Overtaking on motorways? Any issues or is there plenty there to get you by safely?
That’s where my 125 struggles, obviously drivers sees a scooter passing them and they inevitably speed up the buggers!!
Also accelerating, are they quick off the mark?
Scott
ghmpm wrote: ↑Fri Nov 18, 2022 7:41 am I am not familiar with the 125 but my experience with my 2015 300 is it is great on back roads, speed wise. It will do freeways but will lag down on serious uphill rides. Based on this I would assume that the 350 would be even better. So my educated guess is you would be better off with the 350! Good luck.
Thanks for the reply
- DAB
Quick off the mark and no problems overtaking at motorway speeds. I also have a PCX which I find much better in town, but also ride two big V twins, Yamaha BT1100 and MT-01.Scotty125 wrote: ↑Sat Nov 19, 2022 3:55 amthanks for the reply,
Scott
Other rides
Picked up my forza 350 yesterday.
First impressions are very good.
Accelerations a lot quicker, and had a wee spell on the motorway on the way home.
Never went above half throttle as it was just out the show room, but sat at 70 mph no problem on the motorway
350 does feel heavier though and I’m sure the seats slightly taller. Need to look into this, although I could still touch the ground comfortably.
Initial ride, I think the rides lot stiffer, more motorbike like if I’m honest. Maybe because the bikes heavier.
overall first impression very good, usual Honda build quality and the ride is sure footed and very comfortable..
cooling fan coming on will take a bit of getting used too though!!
- 5C475864-50A3-4A77-9931-E5B62A697792.jpeg (478.48 KiB) Viewed 14025 times
