New to me Forza stalling after warm
Hi, I just purchased a new to me Forza with around 4000 miles. Starts and runs well, but I took it out and once the scooter got warm it started running rougher at low speed and then stalled on me and would not restart. I went to a movie and let it cool off and it restarted and got me home. The scooter water temp was only slightly over 1/2 so I am thinking one of two things from my prior auto experience. Ignition Coil or Fuel pump. I will start with some seafoam and then run it until I can repeat the failure. Any common issues that I might add to the testing?
Re: New to me Forza stalling after warm
Don't know if the 2016 Forza was post fuel pump recall. Mine [2014] was bought used and hadn't yet been replaced. Hope your prior experience
bodes well for finding the problem and maybe someone else will chime in with help. There is a website where you can enter the VIN # to find out
about any recalls [USA] that are needed and yet to be carried out.
Was this ever figured out, mine is doing the same.
Yes, sorry for the late reply. It was the gas cap, so some kind of vapor lock. New cap and it cleared up.
