2013 PCX greasing clutch pack bearings ?
8milimeter
Post by 8milimeter »
Since this is a know issue in the 2013 model, I was wondering if the bearings can be greased as a preventative item.
Thanks, 8mm
mymitzi
Re: 2013 PCX greasing clutch pack bearings ?
Post by mymitzi »
Yes but..........before it's noisy. Rode the PCX allot of miles....50K....before changing mine.
8milimeter
Repacked my bearings and sanded clutch pads today. At 2775 miles the bearing were fine, but very little grease on them, it it was almost black. Used High temp bearing grease to repack both bearings. Decided not to use excessive grease, just enough to flush the bearings. plan on inspection and repack every 2500 miles.
pcx888
Color: pearl white
Post by pcx888 »
I just pushed out bearings and replaced with new ones. And add high temp waterproof grease.
2011 White PCX
Aftermarket Thai Seat.
Rear NCY 1000 contra spring.
NCY Textured clutch bell.
jburner
Year: 2013 PCX
Post by jburner »
pcx888 wrote: Tue Aug 23, 2022 4:53 am I just pushed out bearings and replaced with new ones. And add high temp waterproof grease.
Any links to what bearings you replaced with or how you pushed the old ones out? Debating on repairing just bearings or getting a new face for $50
