Front Wheel ABS Sensor
Posted: Thu May 19, 2022 10:07 pm
				How do you remove the Front Wheel ABS Sensor?
I removed the two bolts and then nothing comes apart. I have had it apart a long time ago.
I ride in the rain and salt water a lot in BC, Canada.
Has the sensor corroded to the brake caliper?
I think I broke the wires trying to get it out. ABS light flashes.
If I get the sensor out, does it leave a hole completely through the caliper?
I might end up drilling it out and buying a new sensor.
I might pull the ABS fuse and have a non-ABS Forza for a while. I have no money.
I need food.
I need food.
