Front Wheel ABS Sensor
davenowherejones
Post by davenowherejones »
How do you remove the Front Wheel ABS Sensor?
I removed the two bolts and then nothing comes apart. I have had it apart a long time ago.
I ride in the rain and salt water a lot in BC, Canada.
Has the sensor corroded to the brake caliper?
I think I broke the wires trying to get it out. ABS light flashes.
If I get the sensor out, does it leave a hole completely through the caliper?
I might end up drilling it out and buying a new sensor.
I might pull the ABS fuse and have a non-ABS Forza for a while. I have no money.
I need food.
Re: Front Wheel ABS Sensor
If you removed the bolts and it came out previously, but it doesn't now, it does sound seized.
Haven't you won the lottery yet?
