Hi, on my 2021 the check light has come on, checked manual says go to dealer. Is there any way of doing a reset, it came on after the battery went flat.
Thanks
WH
2021 PGM FI light on, how to reset?
- Year: 2021
- Year: 2021
Re: 2021 PGM FI light on, how to reset?
Hi, whitehorse.
If the engine light is on, you need to find the service connector.
Open the seat and in the battery compartment you will see the service connector.
Now set the ignition to startposition, and shortcut GREEN and BROWN wire on the serviceconnector with a paperclip example.
I did this on mine 2021, and it worked fine
Here is a link to video on youtube
https://youtu.be/4UkDrU0FNwQ
