Hi,
I need to replace the Lower Front Cover/Fairing on my 2016 led spec UK PCX, can someone tell me how this is done?
I have looked around but can only see total removal of body parts really.
Thanks
Lower Front Cover/Fairing removal?
- Color: red
Re: Lower Front Cover/Fairing removal?
Unfortunately the only way to take it off is by removing almost everything. All the body panels are screwed into each other in multiple places. Look at the post by Maddie Dog to install the "bore up kit" he does a good job of step by step to remove the panels.
- Color: White fastest!
Bummer!, thanks for the reply Red Thunder.Red Thunder wrote: ↑Wed Jan 12, 2022 9:34 am Unfortunately the only way to take it off is by removing almost everything. All the body panels are screwed into each other in multiple places. Look at the post by Maddie Dog to install the "bore up kit" he does a good job of step by step to remove the panels.
