Fuel fill door works intermittently
Robd
Post by Robd »
Pcx150/2018
My fuel fill door doesn’t always open when pressing the control button
Any suggestions ?
Thanks
Re: Fuel fill door works intermittently
Once the door is open you should be able to see a latch holding device just under the plastic. Try some WD-40 on it. Sometimes that works. I have had to take my tunnel cover off a few times and clean the mechanism. Also, carry something small with you to help pry it open when it doesn't release. I carry a pocket knife. It just needs a little help sometimes. Remember, it is a mechanical device, operated by a cable, not an electronic device.
Jiggle the key as you press the button, sometimes the seat/fuel switch doesn't unlock properly.
cnikonpete
Post by cnikonpete »
Tap the fuel flap at the same time as operating the switch, my 2018 model does this, tried cleaning/lubricating but can be embarrassing at the pumps if it sticks. One of the few cheap and nasty things I’ve found with mine.
gn2 wrote: Sun Jul 25, 2021 5:08 pm Jiggle the key as you press the button, sometimes the seat/fuel switch doesn't unlock properly.
And make sure the key is in the right position. It still catches me out sometimes.
vagent
Color: Bronze
Post by vagent »
Something flexible, like a "wire tie" will slide under the cover and depress the release lever just enough to release the cover. Is there some way to adjust the cable?
dankly1
Post by dankly1 »
Not sure if you are in the US, but a new lock mechanism (LOCK ASSY., FUEL LID 64440-K35-V00) is only $3.72 on PartZilla if you find that you need a new one.
2019 PCX150
2013 Yamaha FJR1300
1983 Suzuki FA50
Iron Butt Association #80052
C&K
Year: 2021
Post by C&K »
The fuel door not opening when you press the rocker switch is not necessarily a problem with the latch proper. It's a problem with interference between the latch hole on the door and the mating piece it goes into. Press and hold the rocker switch and push the door closed several times and note where it binds at the latch receptacle. When the plastic warms up and expands it gets worse. Just take a mill file and file off a bit of the plastic where my finger is pointing at the hole in the door where the latch loop goes into, so it doesn't bind, and it will open every time. This is on a 2021, but it's the same as the earlier ones.
