Sloppy Oil Change
HondaC110
- Color: Bronze
Sloppy Oil Change
Well, it's once again time to change the oil in my 2019 PCX150, and this time I thought I would try to do it in such a way that I didn't wind up with oil drooling all over the centerstand, etc.
Does anyone have any tricks that they use for doing a neat job of draining the oil?
Thanks,
Jeff
Thanks,
Jeff
springer1
- Year: 2018
Re: Sloppy Oil Change
Get some tinfoil, double it over for strength and make it into a “V” or funnel shape that routes the oil into your drain pan
Leave it on the side stand, drain, Sit on the bike and hold it level to allow remaining oil to drain, put back on side stand and cap?
Ima have to look at my bike when I get home. I don't recall it being an issue.
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Z-Bars
NCY Variator
Pop a bit of duct tape on the stand. The oil will run down that lovely. Pull it off when finished. Sorted.
There was once a How-to on this forum that addressed that issue. Hee is the essence of it.
Make sure you have a shallow oil catch pan under your bike. Use duct tape to keep it against the centerstand. (I use a paint roller pan like painters use.)
Put a round dot piece of velcro on your centerstand close to the oil drain plug.
If you buy oil in a plastic container, save an old one to use as a funnel, or cut down a plastic milk container so that it acts as a funnel. (I prefer the milk container because it gives my hand room to move near the drain plug.)
Put the other side of the velcro dot on the back of the funnel.
Loosen the oil drain plug so that it can be turned by hand.
Hold the funnel against the center stand until the oil starts dripping out around the plug.
Now attach the funnel velcro to the dot on the centerstand and finish loosening the plug, letting the plug drop into the catch pan.
I also put newspaper under the centerstand until I got more proficient.
That's all there is to it. Hope this helps.
HondaC110
- Color: Bronze
It does help, for sure. Thanks very much!
And there is always the oil pump option...
It seems to get what is in out. I removed the drain after using it once and nothing came out.
You'll always get someone that says it doesn't get every last drop out. But neither does a conventional change and it doesn't matter a great deal.
springer1
- Year: 2018
Sounds good - thanks
