Just bought the Red bike second hand for equiv of $2,500 USD , with 4,000km on the clock ( already owned the black one, so got 2 of them now..lol ) - the previous owner has done some stirling mods to it, and i thought i'd share them with you...
Larger throttle body, wide inlet pipe, Hurricane stainless air filter, yellow clutch spring and pcx 2020 weights (18g - The oem ADV weights are 20g, btw) - its super quick when you gas it, but very docile / Honderesque at normal riding speeds.....
The black one, i did the mods myself - Yellow clutch spring, main snorkle cut down by 95%, other snorkle removed, Hurricane stainless air filter - originally put in 15g weights, which i was quite happy with, but having ridden the red one, changed to the 18g weights from the new model PCX - This makes it pull much better and is far smoother......
Whilst not as quick as the red one, at the lights and mid range, it will knock a standard ADV into next week, and is an absolute joy to ride .....
Note - Thai models have rear disc brake.......
Mods for ADV
properperson
Mods for ADV
- 3 - Copy.jpg (499.64 KiB) Viewed 46648 times
- IMG_20201124_084836 - Copy.jpg (343.24 KiB) Viewed 46648 times
- 1 (2) - Copy.jpg (474.13 KiB) Viewed 46648 times
OldManDigo
- Year: 2021
Re: Mods for ADV
how did you tune the fuel and air ratio ?
