ACC wire under the seat?
Rickjds
Year: 2020
Color: Candy Luster Re
Post by Rickjds »
Hi all, I’m looking for a switched (ignition) wire under the seat of a 2020 PCX ABS. It will probably drive a relay powered by the battery with a fuse to power light loads (LED lights, charging accessories, etc.). I found the ground junction in the right front area under the seat. Any advice would be appreciated.
Re: ACC wire under the seat?
So, the 5A accessory outlet in the glove box is not suitable for your needs?
Year: 26 adv 160
I would bring a trigger wire up from the rear for the license plate light. Since it’s going to a relay, it doesn’t have to be any type of high amperage. With the shop manual you can figure out how to intercept the wire along the side, Running to the back. That’s what I did on my Xmax.
Yorkie150
Year: 2018/19
Color: RED
Post by Yorkie150 »
the accessory outlet in the glove box isn't permanent live ...no good for charging as it powers off when the ignition is switched off .
Yorkie150 wrote:the accessory outlet in the glove box isn't permanent live ...no good for charging as it powers off when the ignition is switched off .
Yep, but that is what I thought Rickjds was after re: ' I’m looking for a switched (ignition) wire'
Yorkie150
Year: 2018/19
Color: RED
Post by Yorkie150 »
