Is Castrol Power 1 Engine Oil 10W-30 4T ok in 2018 PCX
CarefulCrysis
Color: Grey
Post by CarefulCrysis »
Is this oil safe to put in my new PCX 125cc?
https://www.amazon.co.uk/gp/product/B00 ... =UTF8&th=1
springer1
Re: Is Castrol Power 1 Engine Oil 10W-30 4T ok in 2018 PCX
Post by springer1 »
Generally a "4T 10W-30 fully synthetic 4-stroke motorcycle engine oil " is fine, but where are you located ? Is it a cold climate?
CarefulCrysis
Color: Grey
springer1 wrote:Generally a "4T 10W-30 fully synthetic 4-stroke motorcycle engine oil " is fine, but where are you located ? Is it a cold climate?
I'm in the UK wet and cold
Yes, that is exactly the correct oil to use.
I use the power 1 racing which is fully synth whereas this is part-synth, but that said it's fine. Any good 4T motor oil in the correct temp range is fine, no need for extra special oil anyway, just do not use 2 stroke oil :)
If your in the UK Halfords often have it in stock or Sports Bike shop have it for nearly £5 cheaper including delivery
https://www.sportsbikeshop.co.uk/motorc ... rod/102570
10W30 is fine from -20 to 40 so perfect for UK.
TheDoors
Post by TheDoors »
I've tried the Repsol full Synth 10w-40 with Excellent results: https://www.amazon.co.uk/gp/product/B00 ... 1OLE&psc=1
iceman wrote:I10W30 is fine from -20 to 40 so perfect for UK.
<actually 10W30 is fine from -15 to mid 30C, usual range for the UK although now it's getting hotter in summer 10W40 is proably better depite Honda stating use 10W30 in all their PCX manuals for the UK (and US?)
AC_ING
Post by AC_ING »
Has anyone try REPSOL MOTO SCOOTER SEMI-SYNTHETIC oil ?
springer1
Post by springer1 »
The container says “2T” doesn’t it ? So it’s for a 2 stroke gas - oil mix engine.
power-full
Year: 2010
Color: preta
Post by power-full »
Sempre usei Castrol racing 5w40 com kit Yuminashi 164cc Estou com 80 mil km sem problemas
oldgoat
Color: Burgundy
Post by oldgoat »
Anyone use an engine oil with "Energy Conserving" printed in the circle on the back of the containers.
I am aware the owners manual says not to use it.
