My PCX just ran a 1/4-mile in under 20sec, y'all!!
grndslm
Post by grndslm »
Boom!!!
Test was done on variator, etc. modded 2015 model. Wonder if my 2013 could go any faster, considering it won't reach 70+ mph? Hmm...
ThIs is the TRC / That Racing Channel app. Pretty fun. :--)
springer1
Re: My PCX just ran a 1/4-mile in under 20sec, y'all!!
Post by springer1 »
That’s quick! Wait for a cooler day with low humidity and see what the improvement is !
Conelite
Color: Blue
Post by Conelite »
I will be doing this test tomorrow. lol
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
grndslm
Post by grndslm »
Conelite wrote:I will be doing this test tomorrow. lol
Where y'at? :-)
I was in full tuck from start to finish, if you can't compete!! :-P Most of the time I've got my work backpack on with a couple pounds of tools in it, too... so not as aerodynamic as I'd like.
I'll have to give it another go now that it's colder. Gloves have kinda hindered me from using the app as much lately.
Conelite
Color: Blue
Post by Conelite »
Finally got a chance to take the scooter out. lol
I couldn't remember if you did a full tuck or not so ima have to try it full tuck. LMAO and with the addition of the winglets on the front, I had extra drag and downforce on the front! LMAO
In all seriousness, almost identical times. Pretty cool. I have some clutch springs i need to throw in. Should make things interesting to compare.
2017 PCX 150
Z-Bars
NCY Variator
Gil
Post by Gil »
I like those wings, where did you get them?
Gil
Post by Gil »
The lag at launch is slowing me down. Will try stiffer clutch springs.
Conelite
Color: Blue
Post by Conelite »
Gil wrote:I like those wings, where did you get them?
Koso makes the real ones but they are on backorder so I went ahead and ordered some cheapy knock off ones from Amazon.
As for your take off, Im going to be changing out my clutch springs soon Gil.
Its the 3 pack from Malossi. Im thinking im going to run the middle set so if you want ill throw the weaker set at you. Just cover shipping. ;)
2017 PCX 150
Z-Bars
NCY Variator
Gil
Post by Gil »
Thanks for the offer, but I also have the spring kit already. I think I have the "touring" spring installed in the clutch already. I'll try the more aggressive ones.
grndslm
Post by grndslm »
Gil wrote:The lag at launch is slowing me down. Will try stiffer clutch springs.
That seems like a GPS issue more than your spring. Or like you just took your hand off the throttle or something.
Pretty sure you'll see a smoother graph after more runs. Sometimes going back the way you came from can give different times due to wind speed/direction, it even as little slope in the land. But your graph is definitely... ahem... wrong..
Gil
Post by Gil »
I agree with you the dips in the graph are bad GPS reception or something. I pin the throttle all the way to 1/4 mile. I do feel the slow takeoff from the slow clutch engagement. I would sometimes lift off the front wheel on take off with the original clutch/bell combo. I'll look for a flatter road to do some acceleration test.
