LED rear strips
ben
LED rear strips
Post by ben »
Finally got round to fiiting the 3528 SMD strips i got...and they are actually better than i thought!
ben
Re: LED rear strips
Post by ben »
In low light
figurehead71
Re: LED rear strips
Post by figurehead71 »
Seem very effective at giving you extra presence from the sides, work well.
Where did you wire them into?
ben
Re: LED rear strips
Post by ben »
Wired to the brake bulb, interesting effect that i didnt expect is that they turn off when i pull the bake but as i have an extra brake bar it works quite well..
If i was to do it again i would use one 90cm strip rather than 2x 30cm as it would look much neater and give out more light but would need the panel drilling.
ben
Re: LED rear strips
Post by ben »
Next i plan to install some 5050 smd to the front as shown, should give good front and side vis. The 5050 strips are 10mm which give out more light (over the rear 8mm i used) so should help but could be tricky to fit...
SmellyTofu
Re: LED rear strips
Post by SmellyTofu »
Looks good. I'm waiting for 5050 waterproof ones to go into the red lens of the topbox.
Re: LED rear strips
Awesome! Where's you get them?
ben
Re: LED rear strips
Post by ben »
£4 from eBay, ha! Should have used 1x 80cm to look cleaner but its still okay.
Re: LED rear strips
They really look nice, but I am a little confused. What is the top set? Is it lights also? (Referring to the 1st and 2nd pictures).
ben
Re: LED rear strips
Post by ben »
The top set is an extra brake light as the large givi box reduced the visibility of the original lamp, it only comes on when the brake is applied.
Re: LED rear strips
Oh, I get that. I bought a Knight Rider sequencing light for ours and installed it above the tail light under the tail overhang.
