(PCX 125) 2013 rear tyre onto 2016?
scootin
Post by scootin »
Hey all,
Currently running a 2016 PCX125, the rear tyre gave out on the dual carriageway last night :x . I've got a spare (for parts) PCX 125 2013 lying around. Would there be any issue putting the 2013's rear tyre onto the 2016's? Also, am I right in thinking a standard bicycle pump with the correct fittings is adequate for keeping scooter tyres serviceable?
Cheers!
Re: (PCX 125) 2013 rear tyre onto 2016?
Not sure about the tyre fitting, guess so, but for bikes, road tires typically require 80 to 130 psi (pounds per square inch); mountain tires, 25 to 35 psi; and hybrid tires, 40 to 70 psi.
As the PCX tyre pressures as nominally 29psi front and 33psi rear, any decent bike pump should work but it will take a lot of work due to the much much larger internal area. I gather your fitting the tyre yourself, so it the beading sits ok I would pop the tyre along to a garage and use their pump to get it there the 1st time.
scootin
Post by scootin »
iceman wrote:Not sure about the tyre fitting, guess so, but for bikes, road tires typically require 80 to 130 psi (pounds per square inch); mountain tires, 25 to 35 psi; and hybrid tires, 40 to 70 psi.
Cheers, iceman.
I'll try the tyre change over the weekend and update here. Might need to invest in something more heavy duty than a bike pump from the sounds of it, but good to know it could work in a pinch. While you're here, do you have any gear recommendations for tyre checks and inflation? I'm fairly rural with no garages around, so going to have to become self-sufficient with this...
Oyabun
Year: `12,`15,`19
Color: black&black
Post by Oyabun »
Yes and yes.
All early year pcx uses the same rear wheel, so you can swap those over.
I use a normal bycicle pump (not the small handheld touring thing, but a normal bycicle shop pump) for all my motorcycles. Also. As long as one doesn't want to get the tires seated after a tire change, but top up/adjust the pressure, they're perfectly fine.
scootin
Post by scootin »
Brilliant thanks for confirming, Oyabun.
scootin
Post by scootin »
Got the tyres swapped, was pretty painless except the 2016's 24mm nut was a right bastard to loosen!
