How do I charge Forza 125 battery fast?
sut1576
Post by sut1576 »
hi
my wife got up this morning and found the battery dead on her bike.
I have removed battery and have a charger on the way.
my issue is I'm not sure what setting to use on the charger when it comes.
the battery says on it 7.4 ah (20 hr) / 120cca it also says 12v 7ah/10hr
it then tells me charging method standard 0.7AX5~10(H) and quick 3.5Ax1 (h)
Now know that means anything to me to be honest,
i have brought this charger: https://www.amazon.co.uk/BUDDYGO-Intell ... 4790&psc=1
would someone be able to advise what charger setting i would need to charge the battery fast, and fast please. I need to try and do it fast as wife needs bike in morning and i will be leaving for work at 4am and can not try refitting battery at that time in the morning,
thank you for any help.
Year: 26 adv 160
Re: how to charge honda forza 125 battery.
Don’t charge a battery fast unless you have some emergency. Use the standard setting, it’ll take 6 hours Or so to equalize at full strength.
sut1576
Post by sut1576 »
can i ask why ? not to fast charge that is.
and do you know what setting i would have to have the charger set at ?
Limey
Year: 16 Forza/16 PCX
Color: Red/Maroon
Post by Limey »
In the battery description is shows a Motorcycle mode. Use that. The battery is 'intelligent' and should adjust charge rate to what is needed. I don't see anything wrong with that.
Snap 2020-09-02 at 11.25.43 (Small).jpg (45.74 KiB) Viewed 46143 times
