Does anyone know if a Honda SH125 top box is compatible with a 2019 PCX OEM rear rack ?
I’m watching one on eBay but not sure if it will fit
SH125 top box
- Yorkie150
- Year: 2018/19
- Color: RED
SH125 top box
Re: SH125 top box
Tough question . . ..
I don't know.
Maybe another U.K. rider out there would have info.
I don't know.
CTPCX
- Color: red
Re: SH125 top box
I'm not sure what the 2019 rack looks like but my 2016 PCX honda rack worked fine with the SH125i honda box. Look up the Honda rack for that box and see if it matches yours.
2015 Ruckus
2016 PCX
2016 PCX
Re: SH125 top box
Did you consider a non-Honda brand top case?
I've got an older model EMGO top case and it's held up quite well having served on three different machines over three decades. Currently, I used heavy plywood to mount it further back on my Zuma factory OEM rack but it did come with a metal pre-drilled mounting plate and other mounting hardware when it was new (which I still have and could have used). It rattles over bumps sometimes but it has never failed me.
The newer version is a bit nicer and varies in price depending upon where you shop. It gets consistently good reviews. It's a simple top case that gets the job done . . .. Comes with mounting hardware and will adapt to most luggage racks. Check out the pics in these advertisements.
https://www.bikebandit.com/emgo-motorcy ... gLDz_D_BwE
https://www.amazon.com/Emgo-72-32440-Tr ... B000GVD0VE
The Givi B29N seems to be a reasonably priced top case as well. Again prices vary but the reviews are generally good and it comes with mounting hardware. A lot of people have concerns about these budget cases when it comes to holding full face helmets so it's good to check out the dimensions to see if they would suit your needs.
https://www.revzilla.com/motorcycle/giv ... k-top-case
