During a routine check of my drive belt, rollers , clutch lining etc... I noticed the clutch lining thickness is now 3.5 mm.
The service manual states to replace the lining when it is 2 mm.
However, it does not state what the standard thickness should be. I just want to know how many kms I have left before I should start worrying. I'm now at 22 000 kms and if I know what they started out as I can somehow make a guess of when I should expect them to be down to 2 mm as my driving style has been and will be kind of continuous so far (as I assume the "wear coefficient" will be similar for a similar driving style in the feature - unless the "wear ratio" is not proportional to current thickness due to things such as more heat built up or whatnot, if that even makes sense
![Smile :)](./images/smilies/icon_e_smile.gif)
Already searched the forum but could not find the answer, so: what is the standard lining thickness of new clutch pads?
Thanks in advance.
