				dash rsing up
				Posted: Sat Jul 11, 2020 10:28 pm
				by CTPCX
				Has anyone had this happen to their PCX? the dash under the windshield has risen up a bit. I am concerned with water getting in there. Anyone dealt with or fixed this issue on their bike?
				Re: dash rsing up
				Posted: Fri Jul 17, 2020 1:35 pm
				by CTPCX
				No one has had an issue like this?
				Re: dash rsing up
				Posted: Fri Jul 17, 2020 2:11 pm
				by Jge64
				I had the same thing happened to my bike, after I took those pieces apart to splice in a power lead. If you take the pieces apart again , you will see that right at the top there is a small little indentation/tab that will make it fit correctly.
				Re: dash rsing up
				Posted: Fri Jul 17, 2020 3:44 pm
				by Gil
				Don't worry about water getting in there. The dash gauges are sealed and only some relays are under the cover.
				Re: dash rsing up
				Posted: Fri Jul 17, 2020 4:25 pm
				Gil wrote:Don't worry about water getting in there. The dash gauges are sealed and only some relays are under the cover.
Oh relay?
				Re: dash rsing up
				Posted: Fri Jul 17, 2020 6:02 pm
				by CTPCX
				thanks for the feedback. It may have happened when I put on the new windshield. I don't recall taking that area apart but I may have put stress on it.
