Question's in the title. I opened up my 2016 Honda PCX150's battery door and that's the battery that was inside. I'm asking because the battery tender has 2 options - lead acid or lithium, and I'm not sure which one to select.
Here's a picture of the battery tender: https://prnt.sc/teeo77
Is the GS Yuasa GTZV8 a lithium or lead acid battery?
- Year: 18 300 xmax
Re: Is the GS Yuasa GTZV8 a lithium or lead acid battery?
It is a standard conventional lead acid battery. As far as I know Honda doesn’t put lithiums in any scooter.
‘15 PCX build thread here:
If its there's a picture on the front of a bin crossed out with Pb underneath, its a lead-acid battery.
If only someone had invented a search engine that could help with this.
Fitting title. Thank you to those who actually stayed on topic and provided an answer.
