Heat Grip connect
Heat Grip connect
Hello people. I want to connect hot grips, but I don't want to connect them to the battery. I bought Oxfford Essential. I want to connect them so that when I turn off the ignition, the Grips turn off. I found two connectors on the left side that are not connected anywhere, but look weak. I'm afraid he damaged the cabling. Grips have 4A. Where to connect cable +? Thank you for your help. Forza 125 2020.
- Gil
Re: Heat Grip connect
On my PCx 150, i connected it to the main relay. It has enough spare amperage capacity for the heated grips.
Thank you.
