Stop/brake light not working 2013 PCX
kabutomz
Post by kabutomz »
I replaced the bulb
I tested another bulb
I get not voltage using a voltmeter
I checked the fuse, it is fine but i replaced it.
Of course, for testing I press breaks front/back
What could be the problem?
Thanks in advance
OldGuywhoTinkers
Re: Stop/brake light not working 2013 PCX
Post by OldGuywhoTinkers »
You need a scooter. Stop guessing. Get a schematic and use any competent voltmeter ! Power starts at the battery, is normally fused. Most cars and bikes work with ground to chassis. A few vehicles may go point to point. For example you cannot ground to fiberglass. Most failures are fuses, bad actual connections, or breaks in the series circuit like a failure in a switch.
Gil
Post by Gil »
On the wiring diagram there is only the brake light switch, fuse and main relay involved in getting the brake light to work. There are also three socket/plug in the wiring harness. Not sure what kind of a climate you live in, but if you live in a humid/wet climate, there might be rust in any socket/plug connection. take some pics of what you are working on. It might help.
Please go into your profile and enter your general location, at least your country. It helps us to help you better.
Now, on to the question at hand. You don't need to have the bike running in order to check the brake light. Just turn the key to ON, where the rest of the lights are turned on. The circuit is simple enough. There are 3 wires to it. One of those wires is green. That is common ground. Of the two that are left, one keeps the light on at all times (not in high intensity mode though). That one is brown. The wire that handles the brake light function is green and yellow.
Perhaps this will help you.
High Contrast Front.jpg (339.3 KiB) Viewed 8530 times
High Contrast back.jpg (360.75 KiB) Viewed 8530 times
My thread with pics may be helpful too: viewtopic.php?f=2&t=577&start=20
As requested above, please add your location to your profile. Outcome: now and in the future all (help) feedback will be accurate or as close to as is possible. That Works! Simple directions are below my post to add yours. Cheers and Good luck with your lighting issue ;)
kabutomz
Post by kabutomz »
I live in Atlanta GA (USA)
Do you live inside the perimeter or in a suburb?
Do you know the history of the bike? Has it been sitting for long enough for a little critter to make itself at home in it? Don't laugh. When I first purchased mine from the showroom a mouse had made a little bed in the taillight area and used the wire coating as part of its bed. I found it when I was checking my tail light. The dealer ended up replacing a part of the harness. It happens. No big deal.
kabutomz
Post by kabutomz »
Mel46 wrote:Do you live inside the perimeter or in a suburb?
I live OTP, 1/2 mile from I-285.
Cables are fine. No rust.
I noticed yesterday there is a piece with two cables. Could be that piece de problem?
It is on the right side of the handlebar.
kabutomz
Post by kabutomz »
By the way , I had a problem with a leak. I rode it back yesterday.
The problem was the oil cap wasn't all the way down. I changed the oil like a month ago.
Thank you so much for your messages willing to help me. I really appreciate it.
Be safe and watch your hands.
Gil
Post by Gil »
Yeah, that's the brake light switch. I have had intermittent malfunction of that switch on my scoot every now and then. I should probably replace it too.
kabutomz
Post by kabutomz »
Gil wrote:Yeah, that's the brake light switch. I have had intermittent malfunction of that switch on my scoot every now and then. I should probably replace it too.
Cool. I will look for the part number and some videos of how to do it.
Thanks
kabutomz
Post by kabutomz »
From the diagram, which one should be ?
Or what is the part name?
Thanks
kabutomz
Post by kabutomz »
Found this:
Is this one the switch?
kabutomz
Post by kabutomz »
I found this video:
kabutomz
Post by kabutomz »
I ordered this one:
https://www.ebay.com/itm/Brake-Light-Sw ... 0083!US!-1
Annotation 2020-04-14 154330.jpg (114.33 KiB) Viewed 8439 times
Did you click and read the link I posted above?
You just provided a photo, here's more describing the parts in your photo. (On my 2011(125) it was part #14 that solved the problem).
https://www.cheapcycleparts.com/oempart ... itch-cable
kabutomz
Post by kabutomz »
Found the part number: 35340-MGS-D31
Annotation 2020-04-14 170542.jpg (92.92 KiB) Viewed 8434 times
kabutomz
Post by kabutomz »
WhiteNoise wrote:Did you click and read the link I posted above?
I didn't see it.
Thanks anyway.
kabutomz
Post by kabutomz »
That's the cable. If the switch doesn't fix the problem, maybe that's the one. But remember I tested and I got no power. So it looks like it could be the switch not passing power.
Well...? Any news? Fixed?
