First of all I would like to make a small apology for not posting enough here but I find the forum quite confusing plus I get no notifications when I get replies.
Anyways
I've ordered a 170CC Malossi upgrade and would like to adjust the final drive gear ratio... to get a higher top speed
Now I've seen some proper posts here but they're quite old... and I have the 2016 model
The post was talking about having an industrial press to get parts out which put me right off.
Now I'm confused again... I can put 1000CC in the PCX but if the gear ratio and or the RPM doesn't change it will have roughly the same top speed (Yes it will be able to withstand wind etc with the more power but thats about it) SO my question is what do I need to order and what ratio and are they easy to fit and with easy I mean drain the gear oil take the gearbox apart fit the new parts and put it all back together with a new seal...?
Another thing that confuses me a little is should I buy for 150cc or for 125cc as it will be a 170 cc after upgrading so will that make any difference or is that just the way its advertised. Now most posts talk about the "Kitaco Final higher gear ratio for Honda PCX 125/150" And then getting the Yuminashi kit... which ratio should I buy from Yuminashi as they have a ton of different ratios.... And is this the way to go??? Thank so much in advance as this would be one step further in rebuilding this bike....
PCX Borekit upgrade Final Drive
patmacessex
Re: PCX Borekit upgrade Final Drive
I'm busy with the same gearbox upgrade, but I'm considering getting the NCY gears. However, I have a 2017 Vietnamese model and I'm trying to find out if the gearboxes are compatible with each other.
I'll post my findings here as soon as I can figure it all out. My other two PCX150s are Taiwanese models.
I have taken apart my transmission a number of times. You will need a bearing puller, and you might be able to get a couple of the bearings off with some deep sockets.
As for the gearing up and what works best, Im still stock on my 2017 and top out at 77mph. Dont care for more. lol Maybe start with bigger tires than stock and the variator. If you are constantly too high on RPMs then I would recommend Gears.
Stock Gears on 20126 PCX 150
Counter gear: 54T
Counter Shaft: 13T
NCY offers: 16*41/16*42/16*46/16*47/17*43/17*44
Counter gear: 54T
Counter Shaft: 13T
2017 PCX 150
Custom Stock Exhaust
Steady Garage Intake
Z-Bars
NCY Variator
Z-Bars
NCY Variator
