Question about top case
gaiusgracchus
Post by gaiusgracchus »
We were thinking about getting a top case (trunk) for the PCX, but have never seen one in person.
It would be nice to have something that could be unlocked easily and removed -- can the Givi or Honda rack mounted top case be removed from the rack easily by unlocking it? Or is it bolted down?
Thanks!
uploader
Re: Question about top case
Post by uploader »
haildamage
Post by haildamage »
indeed, the givi boxes go on in one second and come off like a prom dress!
SmellyTofu
Post by SmellyTofu »
Mine is fixed using the Givi E241 mount on my Coocase. Reason I got the Coocase over the Givi was the brake light system and the remote opening. Although the downside is that the alarm system will draw power out of the battery and it has wiring that you can upgrade (DIY) for brake lights and parking lights. The 36L box takes one helmet and a few other bits.
gaiusgracchus
I guess I am confused because if it it bolted on, it is not easy to remove, but if it is easy to remove it is not secure unless it is locked, right?
haildamage
i guess you need to see how one works. the givi rack is bolted on and the box attaches to the rack with a quick on/ quick release system. it takes less than two seconds to put it or take it off!
gaiusgracchus
Uploader: Re: Question about top case
This may help
http://www.youtube.com/watch?v=qfGfp3AG9sw
Thanks for the link. I see it can be removed -- looks like the lock prevents it from easy removal. The rack looks like it is plastic, surprisingly enough. Hopefully still secure from theft (insofar as possible).
gaiusgracchus
This may help
haildamage
the base is steel and the mounting plate (flat top part) is plastic. it would be difficult to seperate the box from the rack without the key. it would probably be easier to just break into the case.
You can break into just about any topbox with a screwdriver.
SmellyTofu
It is after all a glorified plastic box so a hammer would crack it open
Here's mine.
dinamasu
Post by dinamasu »
gaiusgracchus wrote:We were thinking about getting a top case (trunk) for the PCX, but have never seen one in person.
Thanks!
I bought the Honda one. It looks like Givi makes it for Honda. The latching mechanism is just like a few Givi top boxes that I have had in the past.
The Honda rack is bolted down, but the top box can be removed in seconds. You unlock the box then flip a lever to release the back "catch", lift slightly move forward and it is off. Tha lever is separate from the lever that releases the lid of the top box.
Don "very short person" Inamasu
Northern California
2013 Red PCX150, 2005 Silver Moto Guzzi Nevada, 2007 BMW F650GS
SmellyTofu
Just thinking out loud. If stealing the whole box is an issue, what about drilling holes through the topbox and into the base, then put a bolt from the bottom going up through the base and bottom of the topbox and secured by a split pin so it couldn't be unbolted out.
Taz
Post by Taz »
I like my rack. Today I bought a present for my teenage son. Too big for any topbox.
Box on rack by TazPCX, on Flickr
cessna151
Post by cessna151 »
Taz wrote:I like my rack. Today I bought a present for my teenage son. Too big for any topbox.
Looks like a fun toy. I want one! :D
Magno
Post by Magno »
SmellyTofu wrote:It is after all a glorified plastic box so a hammer would crack it open
Here's mine.
Hi there,
Could you please let me know what is the coocase that you have got? Is it a 28 or 36 litres? Luxury or Classic?
Thank you.
Beto.
former50cc
Post by former50cc »
Definitely there are times when the size constraints of a top case get in the way. I agree there are times when nothing is better than a simple rack for strapping on odd-sized luggage.
Here is mine:
While I was mulling over which Givi top case to get, and whether it should be a Monokey or Monolock, my daughter just went ahead and purchased the Honda version that mounts directly to the Honda rack without a Givi universal mounting kit. It's 37 liter and quite nice, but If I had a choice in the matter I would have hunted down a version color matched to my red PCX. But I'm happy my daughter shared in the expenses of our scooter.
Here is the one that my daughter bought for our shared use:
It pops on and off as instantly as a Givi.
