smart key
halluinoid
Color: blue
smart key
Post by halluinoid »
so I have now owned my Forza 300 for 1 week
each time I have gone out on the bike I have pointed the smart key at the bike , pressed a button on the smart key then turn the ignition switch in a rather random fashion and hoped for the best
NOW after studying the manual I see that you should press the smart key and see the smart key LED turn green, you now proceed to turn the ign lock etc
NOW after studying the manual I see that you should press the smart key and see the smart key LED turn red after you have finished a journey/ parked/locked the bike and going inside your work/house, is that right? 8) I am slowly getting the hang of this I think
2018 Honda Forza 300cc
Year: 26 adv 160
Re: smart key
The bottom line is if you never turn the key off , the battery in the Fob will last about a year. If you turn the fob off and on every time you use the bike, it’ll last two years. Up to you as to your decision. I have a xmax 300 which works the same, I don’t care to go through the multi step operation,I’d rather replace the battery every 11 mo, and I leave mine on all the time.
halluinoid
Color: blue
Re: smart key
but the signal from the key goes through a wall, the manual says
that "wall" in my case is my house! I'm a bit worried the bike can be started by someone (who knows) while my key is just the other side of a wall :P
I dont know, I've had the bike a week, so I could be wrong
Zulda
Year: 2018 (mod 2017)
Re: smart key
Post by Zulda »
If you have a key so close to bike, turn it off after every ride. It's just 2 seconds procedure and you can be 100% sure.
