need to rotate my handle bars slightly due to my long arms.....How do you remove the covers over the bolts on a 2018/2019 ( digital speedo)
thanks in advance .
									Handlebar adjustment - How ??
- Yorkie150
 - Year: 2018/19
 - Color: RED
				springer1
 - Year: 2018
Re: Handlebar adjustment - How ??
I used an exacto knife's sharp blade to pop them out at the edges, but I've heard of using tape to pull them out too.   You'll need to re-level your master cylinder as well if you change the handle bar position.
Look here, quite easy
  viewtopic.php?f=3&t=8642&hilit=handlebars
