I searched the forum for this topic but need more details. What make and model relay for the 2017 pcx150 and where is it located
Thanks for any help.
Replacing the Blinker Relay with one that clicks 2017
Re: Replacing the Blinker Relay with one that clicks 2017
I am not sure that the 2017 model is any different from the previous ones. However, you can easily find out by taking off the windshield, and then the black dash panel cover. It is right under that cover and very easy to change out.
By the way, would you mind taking a few minutes to add your general location in your profile, please? It would help us to be of better help to you, since this is an international forum. Thanks in advance.
Thanks for reply Mel46. Also profile has been updated.
- Year: 18 300 xmax
I don’t think anyone on here has found a flasher that will just plug and play and is loud enuf.There are a few posts talking about the fact that a clicker is not really loud, and you lose it in the wind and acceleration after the turn. There is a post somewhere of someone who mounted a small computer speaker that was louder… Search here…Also look for posts on people that have mounted a self canceling device.
‘15 PCX build thread here:
Welcome and thank you for adding your location, (and Thanks Mel
Re: locating relay, I found this: https://www.hondapcx.org/viewtopic.php?f=2&t=1844
And this: https://www.hondapcx.org/viewtopic.php?f=19&t=1749
I Hope it helps
Here's Louder buzzer info: http://www.scooterfocus.com/scooter_buzzer.html
I Hope it helps
- GeorgeSK
- Year: 13PCX,15Forza
- Color: Both Red
WN - nice find! I'm better than I was when I first got the scoot, but sometimes we still forget, only to notice the flashing a half mile down the road. This little mod does not seem to difficult to pull off. Certainly worth a bookmark. Thanks.
I replaced mine with one that sounds like a truck backup beeper. It definitely reminds me to turn it off.
https://www.amazon.com/dp/B017SJMU1W/ref=dp_prsubs_1
- GeorgeSK
- Color: Both Red
Well that certainly looks easier....
