Hey people. I've just agreed to take delivery of a brand new Honda PCX 125 in a gorgeous red colour.
Can't wait to get out and enjoy my commute free of a car once again.
Any tips that people would give for a first time PCX owner?
Thanks in advance.
John
Hello guys!
- Year: 2018
Re: Hello guys!
Welcome to the group. You might find the mirrors are in too close. A used eb*y set from a cb500 will cure that. For more details on this just do a search on “mirrors “. Also if you want more room to stretch out, pop off the beauty plugs so you can loosen the handlebar bolts and rotate it forward. Then rotate the brake levers & master cylinder back to get them level again. You can easily gain 3”-4” of additional reach doing this.
Re: Hello guys!
A windshield would be a good thing to have since you live where it rains a bit... speaking of, please go into your profile and add your general location, since this is an international forum.
Re: Hello guys!
Must be different on a PCX. On a Forza you can rotate the handlbars up, but brakes/reservoirs are "pinned" to a position on the bars - no rotating.springer1 wrote:Welcome to the group. You might find the mirrors are in too close. A used eb*y set from a cb500 will cure that. For more details on this just do a search on “mirrors “. Also if you want more room to stretch out, pop off the beauty plugs so you can loosen the handlebar bolts and rotate it forward. Then rotate the brake levers & master cylinder back to get them level again. You can easily gain 3”-4” of additional reach doing this.
- Year: 2018
Re: Hello guys!
Bummer, can holes, etc for a new pinning be made? The PCX attachment is via simple compression clamps/bolts.fish wrote:Must be different on a PCX. On a Forza you can rotate the handlbars up, but brakes/reservoirs are "pinned" to a position on the bars - no rotating.springer1 wrote:Welcome to the group. You might find the mirrors are in too close. A used eb*y set from a cb500 will cure that. For more details on this just do a search on “mirrors “. Also if you want more room to stretch out, pop off the beauty plugs so you can loosen the handlebar bolts and rotate it forward. Then rotate the brake levers & master cylinder back to get them level again. You can easily gain 3”-4” of additional reach doing this.
Re: Hello guys!
This will be really helpful. Thank youspringer1 wrote:Welcome to the group. You might find the mirrors are in too close. A used eb*y set from a cb500 will cure that. For more details on this just do a search on “mirrors “. Also if you want more room to stretch out, pop off the beauty plugs so you can loosen the handlebar bolts and rotate it forward. Then rotate the brake levers & master cylinder back to get them level again. You can easily gain 3”-4” of additional reach doing this.
Re: Hello guys!
Will do. ThanksMel46 wrote:A windshield would be a good thing to have since you live where it rains a bit... speaking of, please go into your profile and add your general location, since this is an international forum.
