you you wrote:
Is the oil level rising?
i checked at the dipstick it seems not rising, it stays at the same level since the last time i change my oil,which is about 2 weeks ago.
BPT7594 wrote:Any oil will smell like fuel sometimes because heck to me some fresh oil smells like fuel already.
You will have blowby during normal operation, meaning yes your oil will be diluted with raw fuel over time, however, to which rate of dilution is the right question.
If you're worried, drain the oil and put it in something to measure the volume of oil. If it's much more than 800ml I will be alarmed. But if it's still 800ml, you can scoot along. The piston rings on these babies tend to last very long and are made of reliable material. Don't worry too much.
the oil im using doesn't smell like fuel at all when fresh, i even have the remaining of that oil that i keep about 200ml and its doesn't smell like fuel.
is this fuel dilution perhaps happen because of the fuel im using?
because few days ago i changed my fuel from ron92 to ron95
