PCX 125 2011 GREECE
babisbabou
Re: PCX 125 2011 GREECE
Post by babisbabou »
mymitzi wrote:Wow! That's amazing longevity, Chris. Would you share your maintenance routine with us?. Things like valve adjustments,
Oil change intervals etc. What ever you are doing....certainly works! Thanks for the pictures!
Yes sure, i would love to.
Let's start with the REPAIRS, not maintenance :
1. Speed sensor toasted, also wires worn off, solution replace the sensor, and more wire.
2. Rear light fuse ground did not work, repaired.
3. Differential ball bearings replaced 2 times STARTED using 90w oil !!!
4. idle speed valve,O2 sensor
5. engine partial rebuild at 170.000 cause of extensive oil burning, 500ml every 400km (250miles) changed Piston(set)
6. front brake caliper changed once, recently !!!
7. I blew up the variator 2 times after a burn out on...............wet tiles floor :lol: :lol: :lol: :lol:
i ll add more when i check my files
Maintenance i change the oil every 3.000km(1864miles) using only the BES......noooooo of coarse NOT, just oil, nothing fancy 10-40 and 15-40
Valve clearance when rebuilding the engine, and not fond of doing it again soon :lol: :lol: :lol:
BTW pcx is a nice small scooter but the rear brake, well there isn't one :lol: :lol: :lol: :lol: :lol: :lol:
Of coarse i ride it as hard as i can every time WOT, as much as i can.
pcx 125 2011
enjoy :
[youtube]https://www.youtube.com/watch?v=_KVkpi14REk[/youtube]
babisbabou
also changed the rear suspension once, cause 1 of 2 shocks was leaking oil, changed both with stock shocks. The rear wheel is quite worn on the inside where the pads work it.
Also the double stand in broken on the one side and i have it off the bike attaching it only when i service it.
pcx 125 2011
enjoy :
babisbabou
I have rebuild the forks. Head light wire when cut does, repaired.
pcx 125 2011
enjoy :
babisbabou
I have rebuild the forks. Head light wire was cut , repaired.
I freshened up the cylinder head when i rebuilded it, new valve stem sealers
I have replaced the battery once ! i am on my 2nd battery
Excuse my mistakes, i read the forum late at night before bed.
pcx 125 2011
enjoy :
Yorkie150
Year: 2018/19
Color: RED
Post by Yorkie150 »
where are you in Greece ? we had a house on Ithaca for a few years ...mass tourism and the plunging economy ended our greek odyssey :(
mymitzi
Post by mymitzi »
Many thanks, Chris..........amazing!
babisbabou
Yorkie150 I live on Athens-Greece, yes the crisis has just f@cked us up good...
You are welcome mymitzi
pcx 125 2011
enjoy :
"Also the double stand in broken on the one side and i have it off the bike attaching it only when i service it."
The 2011 PCX has a known problem with the center stand. You have to be aware of the fact that too much weight on it will cause it to break and possibly crack the engine casing where it attaches. Honda reinforced that area in later models. Here is an older thread on the issue.
https://www.hondapcx.org/viewtopic.php?t=5625
babisbabou
Thanks mate, i know there is a problem, faking Honda...but i am not willing to take my engine off, then get the engine to a shop for a weld, at least not now.
pcx 125 2011
enjoy :
RuffStuff
Year: Na
Color: N.a.
Post by RuffStuff »
you can get a new brake lining pressed into your rear wheel, i had an old bike that needed 1 doing but i cant remember if it was a dealer part or an engineering place made it
comecamino
Post by comecamino »
Amazing!
I've noticed that you started using 90w oil on the final gear box, and makes complete sense, since is like a differential. I don't understand why using motor oil in a place like that.
I'm going to start using gearbox oil in that part. and change it every 20.000km, just like my old SYM Joyride Scooter
babisbabou
RuffStuff wrote:you can get a new brake lining pressed into your rear wheel, i had an old bike that needed 1 doing but i cant remember if it was a dealer part or an engineering place made it
i guess the 2nd mate !
pcx 125 2011
enjoy :
babisbabou
comecamino wrote:Amazing!
OHhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh YESS, you are right, it was stupid using motor oil inside a differential...i think that on the 2n pcx, the led one, they have it changed to 90w on the manual too !
pcx 125 2011
enjoy :
