mymitzi wrote:Wow! That's amazing longevity, Chris. Would you share your maintenance routine with us?. Things like valve adjustments,
Oil change intervals etc. What ever you are doing....certainly works! Thanks for the pictures!
Yes sure, i would love to.
Let's start with the REPAIRS, not maintenance :
1. Speed sensor toasted, also wires worn off, solution replace the sensor, and more wire.
2. Rear light fuse ground did not work, repaired.
3. Differential ball bearings replaced 2 times STARTED using 90w oil !!!
4. idle speed valve,O2 sensor
5. engine partial rebuild at 170.000 cause of extensive oil burning, 500ml every 400km (250miles) changed Piston(set)
6. front brake caliper changed once, recently !!!
7. I blew up the variator 2 times after a burn out on...............wet tiles floor
i ll add more when i check my files
Maintenance i change the oil every 3.000km(1864miles) using only the BES......noooooo of coarse NOT, just oil, nothing fancy 10-40 and 15-40
Valve clearance when rebuilding the engine, and not fond of doing it again soon
BTW pcx is a nice small scooter but the rear brake, well there isn't one
Of coarse i ride it as hard as i can every time WOT, as much as i can.
