the specs say it will, don't be scaredeggman wrote:wow now im scared it wont work on my bike i have the 2013
Thank!homie wrote:Warning, insider information. If eggman and I are successful a video will be made and posted for all my YT subscribers of this discovery with a link to that ebay vendor. He will be done faster than a toupee in a hurricane.
When you are torqued down and finished with installation of the clutch you will be tempted to test drive without replacing the CVT cover (don't do that) You will see there is a little bearing that supports the clutch and that final drive shaft in your CVT cover. Good luck!eggman wrote:it was supposed to be here today
That's the spirit! Do show your contraption when you get a chance and your clutch as you say it looks different. I got your ship to... push on young Jedi, you will win soon enougheggman wrote:came up with a easier way to compess the spring i got a board thats like2 feet buy .5 feet then drilled hole in it and place it over nut and put knnes on baord it give me more room to work with
Use the grease packet that will come with your part. Appy all 7 grams of it between the bearings of the Face, Driven set. Kneading it into the actual bearings themselves as well.eggman wrote:can i use wheel bearing grease
