will gy6 parts fit a pcx?
eggman
Re: will gy6 parts fit a pcx?
Which parts?
Having a closer look ... clutch pack should be here for inspection on Monday
http://www.ebay.com/itm/172411708747?_t ... EBIDX%3AIT
http://www.ebay.com/itm/157QMJ-Complete ... 2411708747
- s-l1600.jpg (78.73 KiB) Viewed 5367 times
I have my stock variator in a box, ordered one off ebay today. I will take all the measurements in comparison, count the teeth etc. Maybe these are the same parts Honda uses but only mention every other scooter, quad and go-cart but don't say Hondaeggman wrote:will gy6 parts fit a pcx?
- s-l500.jpg (27.37 KiB) Viewed 5364 times
eggman
the engine mostlyfish wrote:Which parts?
eggman
thats would be so cool if it works on the pcxhomie wrote:I have my stock variator in a box, ordered one off ebay today. I will take all the measurements in comparison, count the teeth etc. Maybe these are the same parts Honda uses but only mention every other scooter, quad and go-cart but don't say Hondaeggman wrote:will gy6 parts fit a pcx?I suspect they are being careful not to claim Honda OEM parts for legal reasons. They look good in pictures and description but one needs to handle, weigh and measure... I will figure out whats going on here
Between the service manuals spec's and actual OEM parts I have laying around I won't need to install these to know if they will work. Look at the white paint in the photo indicating the nuts position, this is exactly the kind of thing you see on PCX equipment. Encourages me to believe these parts are the real deal and will serve on the scooter like original equipment.eggman wrote:that would be so cool if it works on the pcx
eggman
thats would be awesume
- k2apache6.0
I'd wondered about this too. I'm assuming the Chinese copied the parts from the PCX engine for the GY6?
There was a fancy clutch bell on ebay I had my eye on and questioned the seller. He said it wouldn't fit, and at that point I lost interest, but it would be good to view your findings first hand Homie
My PCX mod build here..
eggman
well i ordered one clutch assembly from link above i hope it works on my pcx i even signed up for ebay to get it
Worth it, don't buy the variator in that link above... I think it's smaller. I will know more soon.eggman wrote:well i ordered one clutch assembly from link above i hope it works on my pcx i even signed up for ebay to get it
Confirmed... the ebay variator kit I got is a NO-GO
Although I received a quality part for 16usd the tooth count for the spline on a PCX vario mount is more (finer)
You need go no further than this but I will.
The diameter of the faces is good, the boss is good but the roller carriage is different than a stock PCX part.
Rollers and ramps are also smaller than stock PCX parts from that seller. Maybe we try again with a different seller.
I will continue to watch ebay for compatible drive train parts because it would be cool to get something for 20 bucks like the clutch pack deal which is a perfect match for PCX.
eggman
you are my hero ty for ya work
- k2apache6.0
So the clutch pack works? Did you use the PCX bell housing (clutch bell)homie wrote:Confirmed... the ebay variator kit I got is a NO-GO
k2apache6.0 wrote: So the clutch pack works? Did you use the PCX bell housing (clutch bell)
The 'clutch outer' or "clutch bell" comes with the ebay order and meets the ID dimensions per the SM. You could use it or the one you have on your bike, the part is the same.
http://www.hondapcx.org/viewtopic.php?f=19&t=7674
- k2apache6.0
Cool, thought there might be a spline incompatibility but no, that's great
eggman
mine is on the way well i got tracking number this guy or gal is on the ball
eggman
ive noticed thats the 2015 pcx and 2013 use different part numbers on the driven face. does that mean the clutch assembly above wont fit my pcx
That ebay 30 dollar clutch does not have a part number and it is not sold as OEM Honda at all. We wait YOUR installation for the final word. You will be the first young padawan, do not fail useggman wrote:ive noticed thats the 2015 pcx and 2013 use different part numbers on the driven face. does that mean the clutch assembly above wont fit my pcx
eggman
wow now im scared it wont work on my bike i have the 2013
