Re: Koso Mini Tach
Posted: Sat Jan 17, 2015 10:44 am
installing the wire for the Tach without disassembling you PCX (ok one screw for side plate) and using their cable/wire brackets. This took me less than 10 minutes. (took longer to pause and take pictures)
Slide straightened hangar along throttle cable from back bottom angle up. It will slide right in. I used a plastic covered hangar.
Hangar end visible in wheel well
Tape wire end to second hangar (masking tape)
push hangar with wire from top through cable brackets and grab wire from wheel well
tape wire end to first hangar and pull hangar out. Fish through the Honda cable brackets.
Voila! Spark plug wire and a good bolt for ground behind side plate.
